One user at FME WT suggested, that there could be an option for passing a transformer additionally to Enable/Disable. When Pass would be on, features would pass the transformer. When developing a workspace, many times you have to test the workspace with/without certain transformers. Now the fastest way is to use Ctrl-x and Ctrl-z. Passing a transformer would be like in coding: You can comment certain functionality, and the rest of the code is still executed. In FME, disable just stops the feature flow, and the user has to build new links for passing a transformer.
<strong>This post is closed to further activity.</strong><br />
It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br />
If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br />
