"Bulk" Concatenate Attributes
  • Jun 23, 2025 9:07 AM UTC
  • 162 views
pkno
Forum|alt.badge.img+5
Hello,
I am trying to string together attributes. The difficulty is that the attribute names can vary by dataset.
Generally what i am trying to do is that may look something like this:
DEPTH [m] Measurement 1 Measurement 2 Measurement 3 Measurement 4
0.5 <NULL> 1 4.5 2.1
1 <NULL> 2 2.3 2.2
1.5 3.5 1 1 2.1
2 3.0 1 4.5 <NULL>
What I am trying to accomplish is something like this
DEPTH [m] Measurement1 DEPTH [m] Measurement2 DEPTH [m] Measurement3 DEPTH [m] Measurement4
<NULL> 0.5 1 0.5 4.5 0.5 2.1
<NULL> 1 2 1 2.3 1 2.2
1.5 3.5 1.5 1 1.5 1 1.5 2.1
2 3.0 2 1 2 4.5 <NULL>
Depth and measurement values can be tabstop, space ore comma-seperated, doesnt really matter. In a later step I want to route all Measurements into different features using the AttributeExploder and Aggregator while still keeping the depth information.
I realise this could be easily done using the AttributeManager but this would require manually changing  the workspace anytime a new dataset is being processed, as the names for Measurement[1-4] may change with each dataset. The DEPTH column is not variable though, so there should be some way to do this? Maybe someone has some insight how I could tackle this problem?
Thanks in advance.
Best answer by pkno
Hi ​@takashi ,
the names are completely unpredictable. That said, i came up with a solution which works well enough for me.
  • Jun 24, 2025 2:09 AM UTC
Hi ​@pkno ,
Are the names of attributes storing measurement values completely unpredictable? Or, is there some naming convention - e.g. the attribute names have always suffix 1-4?
Is the number of measurement attributes always four? Or, could the number also be vary?
pkno
  • Jun 24, 2025 4:41 AM UTC
Hi ​@takashi ,
