Archived
a by pass switch to just disable it but keep the data flowing thru it
Related products:FME Form
danilo_fme
u12runm
  • danilo_fme
    danilo_fme
  • u12runm
    u12runm
mikem
a method to disable but you want to let the data flow to an output (the default output - or choose which output) especially when testing but
- disable stops the data flow -- this would be the same as a disable but allows the data thru with no changes
fmelizard
Forum|alt.badge.img+18
  • December 9, 2018
I like the "bypass" word. Would only be relevant tough for xformers with a single input and output, right?
We'd graphically have to show a line around the transformer, as well as "dim" the xformer ala disabled.
Interesting idea.
If folks have thoughts as to how it could apply to multi-port, let's hear...
jdh
Forum|alt.badge.img+28
  • December 10, 2018
I'll admit to having many workspaces with paired connections annotated "enable to bypass..." and "disable to bypass..."
For multiports, I would say clone the data through both ports. It would be the equivalent of deleting the transformer, and having the connection automatically reattach to the previous transformer.
LizAtSafe
Forum|alt.badge.img+15
  • February 12, 2024
Updated idea statusGathering InterestArchived
Idea merged into:
geolassi
All the votes from this idea have been transferred.
