Open
Expose ArcGIS Online/Portal Atttachments thru FeatureReader
Related products:Transformers
maddiel
jblankenship12
nielsgerrits
danilo_fme
warrendev
+22
  • maddiel
    maddiel
  • jblankenship12
    jblankenship12
  • nielsgerrits
    nielsgerrits
  • danilo_fme
    danilo_fme
  • warrendev
    warrendev
  • tcrossman
    tcrossman
  • j.botterill
    j.botterill
  • runneals
    runneals
  • mgg_beca
    mgg_beca
  • gbj1717
    gbj1717
  • spatialexjames
    spatialexjames
  • r5
    r5
  • neilmyoung
    neilmyoung
  • ashish_man
    ashish_man
  • matthewlaw
    matthewlaw
  • aaron_chaput
    aaron_chaput
  • cwinfield
    cwinfield
  • jharriso97
    jharriso97
  • mmccart
    mmccart
  • salvaleonrp
    salvaleonrp
  • ridleyj
    ridleyj
  • oscarwillems
    oscarwillems
  • jakethepainter
    jakethepainter
  • mechomicky_bmcd
    mechomicky_bmcd
  • mb_fdfa
    mb_fdfa
  • thomas.wilson
    thomas.wilson
  • roanvdkruijf
mmccart
Currently, access to AGOL/Portal photo attachment information is available only thru a true reader when the option is enabled. It would be nice to have that option available when using FeatureReader transformers as well. I'm currently using Build 20264 (FME 2020) maybe this has already been released.
Thanks!
nielsgerrits
Forum|alt.badge.img+54
Yes please!
neilmyoung
Forum|alt.badge.img+3
  • March 15, 2023
Having the ability to use the featurereader to read attachments is desperately needed. Additionally it would be helpful if the featurereader supported a where clause when attempting to read ArcGIS Online or Portal layers. What would be super helpful is if when reading the attachments, you could opt to not read the physical attachments. This applies to both AGOL and Portal readers.
Currently I have not been able to read the attachment attributes without also reading the attachment. When we have thousands of records, each with multiple attachments, we now have to read every record and all its attachments in before we can check to see if updates are needed. We want to read only the name, size, etc., and determine only the global IDs that that have rows changed in their attachment table to then use a featurereader with a where clause filtered to read only those records that have attachments that are not currently in our base dataset (or alternatively exist in our base dataset and no longer exist in the hosted feature service layer). This would dramatically increase productivity if this were possible as simply reading in the features currently takes up to an hour on some of our processes.
jharriso97
Participant
  • Participant
  • May 3, 2023
This would be really useful compared to a true reader! I am trying to use an attribute for the Feature Service parameter so that the feature reader wont need to be edited everytime the feature service wants to be changed.
jakethepainter
jakethepainter
For anyone who is interested, I created a sample workspace for reading the attachment metadata with the httpCaller and parsing the JSON and then getting just the attachments I want. I also really like the idea of @neilmyoung​  to have an option just to read the metadata in the Reader/Feature Reader at first, as well. And then could have a reader option to just get the attachments via their url.
j.botterill
Forum|alt.badge.img+37
  • April 5, 2024
The Reader has an option to “Include Attachments”. Why not the Feature Reader?
According to this article, writing attachments is coming in 2024 via a packaged transformer?https://community.safe.com/data-7/how-to-write-attachments-to-arcgis-online-19577
j.botterill
  • April 5, 2024
jakethepainter wrote:
this link appears broken 🤕
nordpil
Forum|alt.badge.img+10
  • April 22, 2024
I found that it was very slow and prone to break to read attachments + features in a reader, I switched to a feature reader and using httpcallers to get the attachment metadata + download attachments that have been changed, which has worked much smoother and faster.
LizAtSafe
Forum|alt.badge.img+15
  • June 15, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • April 5, 2025
