Importing a module in the workspace's directory into PythonCaller
  • May 23, 2025 5:57 PM UTC
  • 236 views
marcel.garate
Participant
TLDR: sys.path does not contain FME_MF_DIR, so I can’t directly import a local Python module. This contradicts FME’s documentation. What am I missing?
Hi all,
I’m having problems importing a local Python module located in the same directory as my FME workspace. Could you help me find out what the problem is or am I missing something?
According to the PythonCaller documentation,
FME will search both the standard Python module locations and the workspace location to find the module to be imported.
However, when I try to import my module in <workspace directory>/feature_processor/__init__.py with the following code:
from feature_processor import FeatureProcessor
I get the following exception:
Message Type: fme::internal::_v0::py::Exception
Python Exception <ModuleNotFoundError>: No module named 'feature_processor'
Error executing string `from feature_processor import FeatureProcessor
Factory proxy not initialized
FeatureProcessor (PythonFactory): PythonFactory failed to process feature
An error has occurred. Check the logfile above for details
To avoid this error, I’ve appended FME_MF_DIR to sys.path, but I’d like to understand why it is that I can’t directly import my module.
I’m currently using FME Form 2024.1.1.1 on Windows 10 x64
Thanks for the help.
Best answer by marcel.garate
Hi ​@takashi
Thank you for your very detailed answer, your examples helped me find the problem:
A workspace parameter of type “Scripted Value” somehow interferes with the appendment of the workspace path into sys.path. For this reason, this has to be done manually.
  • May 24, 2025 5:16 AM UTC
Hi ​@marcel.garate ,
If the FeatureProcessor class is defined in this file saved in the same folder as the “__init__.py” file,
<workspace directory>/feature_processor/feature_processor.py
try writing this code into the “__init__.py”. Just be aware that the preceding . is required in this case.
from .feature_processor import FeatureProcessor
marcel.garate
Participant
  • Participant
  • May 26, 2025 8:34 AM UTC
Hi ​@takashi
Thank you for your reply. If I understand you correctly, this is for the relative import within my module. However, my problem is importing the module within FME Form. Once I get the path to my module in sys.path, I have no problem importing and running the FeatureProcessor class.
  • May 26, 2025 9:37 AM UTC
The preceding . is required if you publish classes/functions defined in other *.py files through "from ... import" statement in the "__init__.py". See the case 1 in the attached workspace examples.
In fact, there are several ways to import a custom pythom module saved in the workspace directory. In some cases, "__init__.py" is not required. See also other cases in the attachment.
marcel.garate
Participant
  • Participant
  • May 26, 2025 4:27 PM UTC
Hi ​@takashi
