How to write attachments to ArcGIS Online?
  • Mar 23, 2023 3:32 PM UTC
  • 8 replies
  • 1368 views
aaron
Forum|alt.badge.img+12
I need to copy records from one hosted feature layer in ArcGIS Online to another hosted feature layer. Schemas are identical. Some of the records in the source data have an attachment (only 1 per feature/record so only in the 0 position in the list). No problem getting all of the records to write from the source to the destination but the attachments are not included. Anyone know how to do bring over the attachments with the rest of the data?
nampreetatsafe
Forum|alt.badge.img+14
Hi @aaron​  FME currently supports reading attachments from AGOL. Writing attachments to AGOL isn't yet supported. I've linked this thread to our internal ticket (reference FMEENGINE-40499). In the meantime, I'm wondering if using this template that's available to download on the FME Hub might help through an API: https://hub.safe.com/publishers/safe-lab/templates/attachmentwriter
aaron
  • Apr 10, 2023 5:36 PM UTC
Thanks @nampreetatsafe​ , we'll take a look at this.
abnan0001
Forum|alt.badge.img+10
  • Nov 25, 2023 9:11 AM UTC
Hi @nampreetatsafe
Any update on attachment writing agol and portal .
Was it implemented
Thanks
nampreetatsafe
Hi @nampreetatsafe
Was it implemented
Thanks
Hi @abnan0001​,
I checked in with the team. Though this work has been pushed longer than expected, it is on our roadmap for early-mid of next year (2024). Good news is that It likely won't be tied to a release of FME, which provides greater flexibility. The plan is to implement it as part of a packaged Transformer.
johnjmillar
Participant
  • Participant
  • May 1, 2024 9:57 PM UTC
Hi @nampreetatsafe
Any updates on the attachment writing?
Thank you,
nomi
Participant
  • Participant
  • May 15, 2024 2:22 AM UTC
Has this been implemented? Any update would be appreciated.
Hi @nampreetatsafe
Was it implemented
Thanks
Hi @abnan0001​,
salvaleonrp
Forum|alt.badge.img+23
  • Dec 3, 2024 1:35 AM UTC
I agree with ​@nampreetatsafe there is no direct write but with the  HTTPCaller it’s possible.
Here’s my response on another community question with some links including my favorite solution with the AGOL to FGDB workflow
salvaleonrp
  • Dec 24, 2024 9:36 PM UTC
I published this blog in ESRI Community that may help answer the question - Source: Web (Non-ESRI) to Destination: AGOL.
https://community.esri.com/t5/arcgis-data-interoperability-blog/really-code-free-web-integration-with-a-touch-of/ba-p/1570435
