Write file in the same directory where source file is
  • Mar 3, 2020 12:48 PM UTC
  • 160 views
lukas108
Forum|alt.badge.img+7
Hello, I need to write the resulting file to the same directory where my source file is, no matter where is the workspace. However, variables cannot be inserted into the writer's destination directory. Can anyone help?
Best answer by takashi
Hi @lukas108, a possible way is to use the FetureWriter to write the destination dataset. You can set an attribute (or a string expression) to the Dataset parameter (i.e. the destination deirectory) in the FeatureWriter.
  • Mar 3, 2020 1:01 PM UTC
Forum|alt.badge.img+54
  • Mar 3, 2020 1:36 PM UTC
Another way to do this is to use a python scripted parameter to set the writer location
Forum|alt.badge.img+63
As a general note: make sure you don't try and overwrite your source file (been there myself...), be very careful about filenames because FME will happily overwrite existing files without warning and if that's the source file while it's also reading it at the same time it ends up corrupting the file.
lukas108
  • Mar 4, 2020 8:38 AM UTC
That´s it. Thank you.
