Extracting m-values from ESRI linear-referenced line feature class
  • June 30, 2025
  • 35 views
smithgk
Forum|alt.badge.img+8
Hello,
I am hoping to get a little guidance on how to properly extract m-values from a ESRI line feature class. In ArcGIS Pro, I can confirm that my feature class is m-value enabled. I need to extract the m-value locations in FME, convert all the vertex locations (with associated m-value) to points, then use the neighbor finder transformer to join the m-value to my point data.
I’m having trouble isolating and exposing the m-values from my source line data. In the Feature Information for the line data, I can see a “Measure (1)” value under Geometry > Line (screenshot below). Under Coordinates, if I click into an individual coordinate the value is displayed as:
-11697066.4549, 4955884.293300003
Measures:
<default_measure> = 0.035799999997834675
 How can use an AttributeExposer (or other transformer) to properly isolated the coordinate and associated m-value data into a list? Once it’s in the list I’ll be off and running and can also handle any unit conversion that is necessary. Any info is greatly appreciated, thanks!
Best answer by takashi
Hi ​@smithgk ,
Take a look at MeasureExtractor transformer.
  • July 1, 2025
Hi ​@smithgk ,
