Multiple column key constraint is wrong interpreted by Postgres-reader
  • Sep 19, 2018 12:01 PM UTC
  • 6 replies
  • 277 views
stalknecht
Forum|alt.badge.img+22
I'm trying to write postgres data from to a new schema. The table I'm reading has a unique constraint on two columns like this:
CREATE TABLE public.real_right
    share_numerator smallint,
    share_denominator smallint,
    upi character varying(50) COLLATE pg_catalog."default" NOT NULL,
    party_id character varying(100) COLLATE pg_catalog."default" NOT NULL,
    is_deleted boolean,
    CONSTRAINT "PK_REAL_RIGHT" PRIMARY KEY (upi, party_id)
WITH (
    OIDS = FALSE
TABLESPACE pg_default;
If I take a look at the reader it shows me only a primary key at upi
When I use Table definition: Copy from Reader ...
Then the bulk data load fails because of the primary key violation.
So the question is: Does the postgres reader supports multiple key constraints?
And is there a workaround?
thanks in advance
Best answer by david_r
I just tested with FME 2018 and the PostGIS writer, it seems indeed that FME doesn't manage multiple field primary keys for table creation:
Writer setup:
Resulting table created by FME 2018, we see that only "col1" has been set as the primary key:
My suggestion is that you manually create (or fix) the target table and not let FME create/recreate it for you.
  • Sep 19, 2018 12:13 PM UTC
Writer setup:
stalknecht
  • Sep 19, 2018 12:58 PM UTC
Writer setup:
I'm not happy with the answer but thanks for your input. I will post an Idea on the forum.
  • Sep 19, 2018 1:01 PM UTC
I agree it's not great. If you post the link here I'll give the idea a vote for sure.
stalknecht
  • Sep 20, 2018 6:12 AM UTC
  • Nov 20, 2018 3:31 PM UTC
Writer setup:
I experienced a similar problem with MS SQL Server. FME does not either handle Multiple Primary Keys when writing to MS SQL Server. Is this a general FME limitation?
nampreetatsafe
Forum|alt.badge.img+14
Hi @stalknecht, @david_r, and @tomchr.
Thanks for sharing your experience with trying to use composite keys in FME.
FME does support writing to existing tables that have multiple keys already defined or creating a table in SQL (i.e. in a statement before translation), which is what @david_r suggested.
As you've discovered, FME doesn't yet support reading such tables and only assigns one primary key to the attributes that are read in.
@stalknecht, thanks for posting your idea for our team to consider. It will help us prioritize any future improvements.
