It looks like that either the Postgres Reader and Writer doesn't support multiple column / field constraints. See discussion:
https://knowledge.safe.com/questions/78765/multiple-column-key-constraint-is-wrong-interprete.html?childToView=78768#answer-78768
If you ask me it's a shortcomming that should be fixed!
Please add multiple column/field constraint support also for MS SQL and Azure SQL database writers
