Cannot fill timestamptz field in postgres table using postgres writer
  • Nov 13, 2018 8:03 AM UTC
  • 8 replies
  • 274 views
stalknecht
Forum|alt.badge.img+22
When I try to add data to a timestamptz field in postgres using the postgres writer it gives the following error:
Value of attribute 'start_date' could not be converted to type 'timestamptz'. Feature will be logged and skipped
WARN Â |+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
WARN Â |Feature Type: `admin.real_right_version'
WARN Â |Attribute(string) Â : `start_date' has value `2018-11-13 09:43:58.3875761+01'
I'm using FME 2018.1 and postgressql 10.5
Best answer by ebygomm
@DateTimeNow() should give exactly the same result as the timestamper - both produce output in Standard FME Date/Time format - you shouldn't need to format either before writing to postgres
  • Nov 13, 2018 8:07 AM UTC
Try converting the "start_date" value into the Standard FME Date/Time Format before writing.
stalknecht
  • Nov 13, 2018 8:44 AM UTC
Thank you, @takashi @DateTimeNow(utc) did the trick
Forum|alt.badge.img+54
  • Nov 13, 2018 8:52 AM UTC
stalknecht
  • Nov 13, 2018 8:55 AM UTC
But this doesn't work for me. Only the DateTimeStamper did the trick. Maybe it has something to do with the UTC offset
  • Nov 13, 2018 8:59 AM UTC
@DateTimeNow(utc) if you need UTC time
stalknecht
  • Nov 13, 2018 9:00 AM UTC
arnovananrooij
I have the same issue here now. I don't really get how you solved it. I have an attribute with date and time from a gml file and i want to insert this in an postgis database with attribuite type timestamptz.
  • Jan 16, 2020 11:07 AM UTC
If you are using the PostGIS writer to write the features into the database table, you will have to format the datetime value with the Standard FME Date/Time format.
See here to learn more: Standard FME Date/Time Format
