Update existing data in postgres
  • Sep 19, 2016 7:44 AM UTC
  • 6 replies
  • 222 views
Hello,
I think there is a problem with the update of postgres data. I have a table with uuids and dates. The statements for those types are not constructed correctly.
FME throws an error for the date like this:
'ERROR: syntax error at or near "2009"
LINE 1: ...NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, E'2009-10-26...
You can see that it is used like a string. Same happens usually to the uuid - there no quotes are inserted. Postgres usually expects quotes around the uuids.
I also tried the DatabaseUpdater, but the same error occured.
mark2atsafe
Forum|alt.badge.img+59
Hi @aleho
I think this might be a known issue, but am not sure. Can you contact our support team (safe.com/support) and ask them. Tell them I think it might be related to PR#51142 ("POSTGRES: UPDATES with column type UUID are failing"). They will be able to confirm, increase the priority on the issue, and maybe provide a workaround.
Apologies for any inconvenience this is causing.
Mark
Forum|alt.badge.img+7
Hi @aleho,
Is it possible to keep us informed about this? I stumbled upon this issue to and end up 'solving' it by using an SQLExecutor instead.
Thanks in advance!
  • Jul 23, 2018 3:06 PM UTC
I've had the same issue trying to update a PostGIS database with UUID fields - I also had to use an SQLExecutor (plus a GeometryExtractor set to 'OGC Well Known Binary' to access the geometry) as a work around. I've contacted support too - hopefully this will be resolved soon.
jwe
  • Nov 5, 2018 7:26 PM UTC
Hi @aleho
Mark
Problem still exists in 2019 beta, so I contacted support. Apparently the fix is being worked on, but I requested for it's priority to be escalated. No workarounds are currently suggested by Safe.
I've just written my UUID's to a CSV, and will be updating my data through sql statements. (using a SQLExecutor in FME triggered the same error for me.)
Thanks for the suggestion Mark!
winkel_tripel
This problem still appears in FME 2019.1. I am unable to update values in a postgres uuid column. An alernative workaround is to place an AttributeManager before the writer and add quotes to the uuid values (e.g. change attribute value of the uuid column to '@Value(uuid)' ). I have contacted support to advise on the status of this longstanding issue.
nampreetatsafe
Forum|alt.badge.img+14
@rhartley, I'm sorry you ran into this issue. I see your support case has been attached to the existing ticket for this issue (internal reference FMEENGINE-10424).
