startup python script
  • Feb 19, 2013 8:04 PM UTC
  • 91 views
I am using FME 2012 and would like to write a startup python script in which I can import a python module and call that module's function. I used to be able to do this with pyfme but with FME 2012 I have to use fmeobjects and it throws an error when I do. Two simple test cases below.
What might be causing the error? Looks like when I import the custom module, fmeobjects is not getting recognized.
Embedded script (works):
import fmeobjects
def audit_start():
    logger = fmeobjects.FMELogFile()
    logger.logMessageString("audit_start()")
    for name,val in FME_MacroValues.iteritems():
        logger.logMessageString( "   %s:%s" %(name,val))
audit_start()
Imported script (error):
import audit
audit.audit_start()
audit.py
import fmeobjects
def audit_start():
        logger.log( "   %s:%s" %(name,val))
Error: Python Exception <NameError>: global name 'FME_MacroValues' is not defined
  • Feb 19, 2013 9:35 PM UTC
Solved. __main__ namespace have to be imported:
import __main__
import fmeobjects
def audit_start():
    for name,val in __main__.FME_MacroValues.iteritems():
mark2atsafe
Forum|alt.badge.img+59
Just to mention, pyfme was replaced in FME2012 to solve a bunch of problems and improve our Python support. You can find more details at:
http://fmepedia.safe.com/articles/How_To/New-Python-FME-Objects-API-in-FME-2012
  • Feb 22, 2013 1:47 PM UTC
Another suggestion would be to add the log file object and the FME_MacroValues dictionary as a parameter to audit_start(), e.g.:
In the workspace
import audit
audit.audit_start(fmeobjects.FMELogFile(), FME_MacroValues)
In audit.py
def audit_start(myFMELogger, myMacroValues):
    myFMELogger.logMessageString("audit_start()")
    for name,val in myMacroValues.iteritems():
        myFMELogger.log( "   %s:%s" %(name,val))
I would consider this a slightly better approach as the coupling between FME (the caller) and your external script is less tight.
David
