Using the String Concatenator...
  • Apr 30, 2014 8:06 PM UTC
  • 175 views
With String concatenator, can I only concatenate an output for rows where data is null or blank in a different field? Example: I have a field with addresses, only some entries are null or blank. I do have house numbers and street names in their own respective fields for every entry.  I want to concatenate ONLY rows where the full address field is null or blank
Best answer by takashi
I think there are at least two approaches:
1. Use a Tester to determine if the full address field is null or blank; concatenate strings for Passed features with a StringConcatenator.
2. Use the Conditional Value setting functionality of the AttributeCreator. If the full address field is null or blank, create a concatenated string and assign it to the field. Otherwise, do nothing.
Takashi
  • May 1, 2014 1:52 AM UTC
Takashi
