Transformer values
tsig
Participant
  • Participant
Hello everybody, i want to know if someone know how i can to do to rename a value in an attribut ? which name for the transformer ? thank you !!
Bonjour tout le monde, je voulais savoir si quelqu’un savait comment modifier une valeur dans un attribut ? quel transformer dois-je utiliser ? Merci par avance.
Best answer by andrewj74
tsig wrote:
Thank you for your help.
Effectively it is the good transformer , great!
However i have three same value, and i want just rename two.
Do you know how i can to do ?
454-454
454-455
454-456
you just put the the value in the input value “454-455” and then what you want it mapped to in the output value. if you want to map 2 values you can add multiple rows to this part.
or do you mean that you  have 3 of the same value and you only want to map one of them. if its just one value i would do a tester to filter out the value e.g 454-455 and then add a sampler to get one row, and then put that value in to the attribute value mapper.
 if there are lots of potential values where there are more than one an you only want to map one value, you can add a group by clause in the sampler, and group it by the column that has duplicate values where you only want to map one
andrewj74
  • June 13, 2024
attribute value mapper :)
andrewj74
  • June 13, 2024
for your “output attribute” name type in the “input attribute” name if you dont want to create a separate column and just update the existing data. also add you attribute to the default value if you are not altering all values
e.g.
tsig
Participant
  • Participant
  • June 17, 2024
454-454
454-455
454-456
andrewj74
  • June 17, 2024
454-454
454-455
454-456
tsig
Participant
  • Participant
  • June 17, 2024
It’s good, i have success with your methods.
Thank you for your explanation, it’s very clear.
