Geocoder with ArcGIS Online
  • Sep 11, 2025 11:22 AM UTC
  • 115 views
pmcpherson
Forum|alt.badge.img+11
For years I’ve successfully used the Geocoder transformer with the ArcGIS Online service. Now with the recent upgrade to Version 2025, it appears to be broken. I’ve read a bunch of recent articles concerning the new (?) ArcGIS connector package, but nothing seems to relate to the Geocoder transformer. Anyone else having similar problems?
Best answer by pmcpherson
I tried changing the authentication type from “Web Service” to “Generate Token”, and it seems to be working in Form and Flow, at least for now. Time will tell, I suppose.
pmcpherson
  • Sep 11, 2025 11:56 AM UTC
desiree_at_safe
Forum|alt.badge.img+25
Hi ​@pmcpherson. You’re right! the ArcGISConnector package is relatively new, so it’s possible it may interact unexpectedly with transformers like the Geocoder.
I’m glad to hear switching the authentication type is working for you for now, but this is a really odd issue to run into!
Submitting a support case would really help us dig into it:  https://support.safe.com/hc/en-us/p/Support
If you don’t mind, please share a sample or screenshot of your workflow in that support ticket. That’ll help us reproduce your exact workflow and see if there’s another angle to troubleshoot.
