Tiler - convert a huge polygon to individual tiles (1 tile = 1 file)
  • November 4, 2015
  • 8 replies
  • 112 views
I have read a Huge polygon and used a Tiler transformer. I specified the Tiling Type to "Number of Tiles"
and assigend the horizontal and vertical numbers..How do I then configure the Writer to save 1 tile to 1 individual file?
thanks
Jubert
Best answer by takashi
Hi Jubert,
Consider using the "Fanout". See here to learn more.
FME Workbench About Fanout
Takashi
  • November 4, 2015
Hi Jubert,
Takashi
  • November 4, 2015
Hi Jubert,
Takashi
Hi Takashi,
thanks for the feedback, yes its fanout to save the files into multiple files..however the Tiler Transformer does not generate an attribute Index which can separate each tile generated.
It creates two attributes though.. an _column and an _row.. but If I assign a single attribute for the fanout. it would only separate it into either _column or a _row.
  • November 4, 2015
Hi Jubert,
Takashi
You can create a unique identifier based on _column and _row. An easiest way is to concatenate them with the StringConcatenator. For example:
@Value(_row)[delimiter]@Value(_column)
[delimiter]: any character. I want to put an underscore here, but the system will not display that correctly...
  • November 4, 2015
Hi Jubert,
Takashi
thanks! there is a trick though...simply by concatenating the two columns it would create duplicates so another value should be added..for example "_"
  • November 4, 2015
You are right. A delimiter is necessary in this case.
If the format of the destination dataset is a folder-based one (e.g. Esri Shape), the destination file name (i.e. feature type name) can also be created in the feature type name field of the writer feature type properties dialog (FME 2015.1+).
e.g.
  • November 4, 2015
@dewetvannieker, this may reproduce the issue (missing underscores, unexpected Italic).
@Value(_row)_@Value(_column)
dewetatsafe
Forum|alt.badge.img+5
  • November 4, 2015
Thanks Takashi. We'll look into this. As a workaround, you may be able to use the HTML entity & # 64; @
  • November 4, 2015
Hi @takashi @dewetvannieker,
there is another issue I guess, I left it running over night and takes forever. posted a new question.
https://knowledge.safe.com/questions/19647/tiler-b...
cheers!
