Spatial Relator with surrounding areas?
I used SpatialRelator to find relations between areas, when Requestor contains Supplier. In Output i got the contained areas (supplier). Is there a way to get the surrounding areas (requstor)?
Best answer by takashi
Hi @tramm, try using "Requestor is Within Supplier" instead.
See here to learn more about the Spatial Relations: Spatial Relations Defined
  • October 10, 2018
  • October 10, 2018
The SpatialRelator always outputs the Requestor features, and the features can have attributes of spatially related Supplier feature(s). What result do you want?
  • October 10, 2018
ahh right... just need to change requstor with surrounder
