safe.robj-detect-pkg failed to install
  • December 11, 2019
  • 22 views
I tried installing the safe.robj-detect-pkg in to FME desktop 2019.2 build 19801 and I got the following error
RasterObjectDetectionModelTrainer.fmx ignored because it was created with a newer version of FME Workbench
I downloaded and installed 2019.2.1 build 19813 and the same error occurred
Transformer safe.robj-detect-pkg.RasterObjectDetectionModelTrainer version 1 in file C:\\Users\\apadilla\\AppData\\Roaming\\Safe Software\\FME\\Packages\\19813-win64\\transformers\\safe.robj-detect-pkg\\RasterObjectDetectionModelTrainer.fmx ignored because it was created with a newer version of FME Workbench
Transformer safe.robj-detect-pkg.RasterObjectDetectorSampleGenerator version 1 in file C:\\Users\\apadilla\\AppData\\Roaming\\Safe Software\\FME\\Packages\\19813-win64\\transformers\\safe.robj-detect-pkg\\RasterObjectDetectorSampleGenerator.fmx ignored because it was created with a newer version of FME Workbench
Transformer safe.robj-detect-pkg.RasterObjectDetectorSamplePreparer version 1 in file C:\\Users\\apadilla\\AppData\\Roaming\\Safe Software\\FME\\Packages\\19813-win64\\transformers\\safe.robj-detect-pkg\\RasterObjectDetectorSamplePreparer.fmx ignored because it was created with a newer version of FME Workbench
Best answer by chrisatsafe
Hi @apadilla,
It looks like the package that you downloaded and tried to install was accidentally updated and published with a 2021.0 transformer which is likely the cause of the failed install. Can you remove the package from FME Options > FME Packages (if anything was installed), then try installing the Raster Object Detection Trainer v 0.2.6 package? It looks like this is isolated to v 0.2.5 so that should resolve the issue.
Hope that helps!
chrisatsafe
  • December 16, 2019
Hi @apadilla,
Hope that helps!
