Extracting name and description Tags from xml_fragment Using XMLQueryExtractor
  • Aug 19, 2025 8:15 PM UTC
  • 126 views
francisco_1988
Forum|alt.badge.img+5
Hi everyone,
I’m having some trouble with the XMLQueryExtractor. I need to extract from the xml_fragment field the values inside the <name> and <description> tags.
Currently, the output from FeatureJoiner is in the format:
Theme | ID | xml_fragment
What I need is for the extraction to produce the following table:
Theme | ID | xml_fragment | name | description
Best answer by takashi
I would recommend you to insert a ListExploder to explode the “field{}” list immediately after the Counter and see how it works firstly. Once you have understood how it works, I think that you can then find how you can use the transformer to achive your goal.
  • Aug 19, 2025 8:42 PM UTC
Hi ​@francisco_1988 ,
I don't think you need to use XMLXQueryExtractor to extract name and description, since XML reader has extracted those values as a list attribute called "field{}" already.
You can just use ListExploder to extract the values of name and description from the list.
francisco_1988
I'm not at my workstation right now. Would your suggestion be to insert a list builder after my feature joiner?
  • Aug 20, 2025 3:25 AM UTC
francisco_1988
Thank you !!!
