Python Caller - using arcpy input error (already pointed dll)
  • June 24, 2015
  • 75 views
Hey yall... I posted my caller script below. I can get it to work for setting an attribute so I know I am reading and passing out the feature correctly.
But when I go to actually run my arcpy buffer it gives me the following error:
Python Exception <RuntimeError>: Object: Error in executing tool
Traceback (most recent call last):
File "<string>", line 12, in input
File "C:\\Program Files (x86)\\ArcGIS\\Desktop10.3\\ArcPy\\arcpy\\analysis.py", line 691, in Buffer
raise e
RuntimeError: Object: Error in executing tool
Error encountered while calling method `input'
PythonFactory failed to process feature
Any ideas on what I might be missing below to get the input feature to read into arcpy correctly?
ALSO I CANNOT USE THE BUILT IN BUFFER TOOL IN FME FOR THIS.
Script::
import fme
import fmeobjects
import arcpy
# Template Class Interface:
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self,feature):
        Purple = None
        arcpy.Buffer_analysis(feature, Purple, "BUFFER_FIELD", "FULL", "ROUND", "NONE", "", "PLANAR")
        self.pyoutput(Purple)
    def close(self)
        pass
Best answer by takashi
I'm not familiar with arcpy, but I can say that any arcpy method will not accept FME objects directly since there is no compatibility between arcpy and fmeobjects. "feature" in the context is an instance of fmeobjects.FMEFeature class.
Although "fmeobjects.FMEFeature.buffer" method can be used to create buffer of the input feature alternatively, why cannot you use the Bufferer transformer?
Takashi
  • June 25, 2015
Takashi
