Modeling buildings' roofs in LoD2 using las and shp files
  • May 23, 2021 8:38 AM UTC
  • 293 views
mahbouberezaiee
Hi. I am trying to model some buildings' roofs in LoD2 using point clouds(las) and some shp files from arc gis, but I cannot find the right transformation. I have seen the sixth demo in this webinar,
https://www.safe.com/webinars/gain-total-control-of-your-lidar-and-point-cloud-data/
but they are just roofs in LoD1.
Can someone help me how to do that?
Many thanks
chrisatsafe
Hi @Mahboba Rezai​ ,
Have seen the Create a 3D model using point cloud and vector input recording? It might help you get the desired result.
mahbouberezaiee
Hi @chrisatsafe​
Thank you for your attention and reply. I solved finally the problem using SurfaceDraper and it works well.
Hi @chrisatsafe​
hello, did it work to make LOD2 buildings with las and shpfiles?
