Is there a way to get the Excel Writer to honour the cell width of the template file?
mmacfarlane
Forum|alt.badge.img+7
It used to work in older versions (2020?), but now will only use the value set in the writer. If I set it to 0 for automatic width, it results in "Error running translation"
I need the cell size to be a specific decimal value, but the writer will only let me set an integer for the cell width.
Best answer by markatsafe
@mmacfarlane​ Thanks for the workspace & data. I've reproduce the issue. This has been fixed for FME 2021.2 which is scheduled for release in early November. betas are available here
  • October 4, 2021
@mmacfarlane​ Do you have a little example of the template and data. I think FME should be honouring the template
mmacfarlane
  • October 4, 2021
Hi Mark,
I've thrown together a quick workspace that replicates the issued (though 0 width for automatic isn't causing the error running translation, weird!). The writer is still not honouring the template's width though.
mmacfarlane
  • October 4, 2021
mmacfarlane wrote:
Hi Mark,
Hmm. Thought I had attached both the template and workspace. Here's the workspace
  • October 4, 2021
mmacfarlane
  • October 4, 2021
Thanks!
dollyns
Participant
  • Participant
  • July 4, 2024
mmacfarlane wrote:
Thanks!
Hi Michael,
Could you share the configuration that makes the Excel Writer preserve the cell width of the template?
I was trying to do the same but it didn’t work. I configured it to use the destination sheet as the template, and not to overwrite the file.
In “User Attribute” tab, I chose “Automatic” for attribute definition. But if I set the “Cell Width” to all 0s, it will auto fit the width, not preserverse it.
Below is how the file looks like before and after execution (using “Automatic” definition). I also attached the screenshot configurations.
BEFORE:
AFTER:
crystalatsafe
Forum|alt.badge.img+22
Hi @dollyns
It looks like that workspace mentioned was missing from this thread but we have reattached it so you should now be able to see how @mmacfarlane set up the Excel writer.
Which version of FME are you using? I believe all versions after 2021.2 will honour all formatting from the template file.
