i have a 3d dgn file in that 3D buildings generated from Lidar data....now i have to group that features as a seperate building in FME...so please provide answer how to do that?
  • April 27, 2017
  • 73 views
Best answer by itay
do you have anyway to distinguish the buildings? Such as a building footprint?
itay
Forum|alt.badge.img+19
  • April 27, 2017
Forum|alt.badge.img+63
I don't have a conclusive answer, but if all you have is a LIDAR point cloud and need to extract buildings out of it there's a few things you can try. Keeping in mind that both of these will find "bumps"... anything that stands out from the terrain, so buildings, trees, parked cars, garbage bins, anything.
  • Create contours and build polygons out of those, grouping by elevation value, dissolve the resulting polygons and the results should be your bumps.
  • Build a TIN out of the point cloud and look for closed rings of triangles with a high slope value.
Both methods are time consuming and will most likely yield results that need to be interpreted further. I'm trying to find trees in a LIDAR dataset and would be looking at area and circularity as criteria.
  • May 4, 2017
yes i have building footprint
