HTTPCaller - How to get a value from the response_body
  • Aug 4, 2021 3:03 PM UTC
  • 712 views
plynn
Forum|alt.badge.img+10
I am using the HTTPCaller transformer to perform a GET. How do I take the response and pull out specific attributes and their values?
For example, I pass in a list of 5 asset numbers to the HTTPCaller. It performs the GET to return all associated information for each of those assets. I need to pull out, from the response body, only the assetnum and status.
itsmatt
Forum|alt.badge.img+48
  • Aug 4, 2021 4:45 PM UTC
It depends on the response. The response is probably JSON. In this case you need use the json tools to extract the data.
​Have a read of this article: https://community.safe.com/s/article/json-transformations
There should be some helpful tips​
plynn
  • Aug 4, 2021 5:31 PM UTC
The response is actually XML.
gazza
  • Aug 4, 2021 8:46 PM UTC
There are a number of ways to do this but the XMLFlattener is probably the easiest to use.
itsmatt
  • Aug 5, 2021 6:49 AM UTC
Yep, XMLFlatterner is probably the way to go. You might need to experiment with the settings a little to get the result you want. Check out the documentation of the transformer for help
