How to transform 3d model to 2d geometries and height property
  • Oct 5, 2020 1:57 PM UTC
  • 431 views
I have a building box 3d model create from ketchup
How to I export feature include geometry is bottom face of model and propety is height of model from a 3d model?
The feature template
"type": "Feature",
   "properties": {},
   "geometry": {
    "type": "Polygon",
    "coordinates": [
       y,
       x
       y,
       x
Best answer by itsmatt
Use a BoundsExtractor to extract _maxz of the model. After that use a SurfaceFoortprintReplacer to get the 2D footprint of the model. You should now have a polygon with an attribute called _maxz.
The template looks like Geojson so you can use a GeoJSON writer to output the polygon. If you want to rename _maxz you can use an AttribiteRenamer​.
itsmatt
Forum|alt.badge.img+48
  • Oct 5, 2020 8:07 PM UTC
It worked for me
Thank you very much
itsmatt
  • Oct 6, 2020 6:37 AM UTC
It worked for me
Thank you very much
Great to hear!
