How to create solid geometry for citygml (lod1Solid)
  • Apr 20, 2023 12:14 PM UTC
  • 213 views
limo
Forum|alt.badge.img+8
we have some PoylgonZ geometries with multipe polygons per building. For each polygon we have different heights.
Now we are creating building models in citygml with citygml_lod_name = lod1Solid. This is working already with this workflow:
imageBut now we have for each solid one building element. Then I thought on the transformer aggregate to aggregate the solids for each building (by gmlid).
But then I have MultiSolids which I can´t write to CityGML (lod1Solid).
How can I create only one Solid for each building?
Or do I have to use lod1MultiSurface?
Forum|alt.badge.img+54
  • Apr 20, 2023 12:26 PM UTC
Assuming you are after something like this?
imageHave you looked at the custom transformer SolidDissover?
itsmatt
Forum|alt.badge.img+48
  • Apr 20, 2023 12:59 PM UTC
Yeah, either dissolve into one Building as @ebygomm​ suggested OR if you want to keep the Information from both features you can create BuildingParts instead.
I've attached an example showing both cases
limo
  • Apr 21, 2023 5:50 AM UTC
Ah thanks for your hint! That should be the transformer I need.
But I got an error message: "invalid geometry".
All features are solids according to "geometry filter".
invalid geometry:
