How to add csv-attribute values to autocad block attribute value
  • Mar 31, 2020 3:14 PM UTC
  • 223 views
sprongandre
I have a *.csv-file with values, I would like to put them in a Autocad block attributes:
The issue is that the 'pino'-values which I filled in by hand will come over. The values from the csv won't (value from Sheet Name 2).
I can't get it, who can help me please? :-)
Thanks!
acad_excel2acad_Safe.fmw
0002_Sheet Name.csv
Best answer by cdalessandro
You have to merge 2 features into one so you will get a single feature with same attribute. Use for that FeatureMerge transformer whit "1" values in requestor and supplier fields. If you'll have troubles, share us dwg and csv sampled files
Your question is unclear, in the image the Creator is missing PR_META_2. If the value for this field originates in the csv there is no way to get the value into the creator. It would be helpful if you had a workspace to share.
cdalessandro
Forum|alt.badge.img+4
  • Mar 31, 2020 5:52 PM UTC
sprongandre
Yes that did the trick, thanks a lot! :-)
