How do I create an Elevation profile?
aron
Forum|alt.badge.img+16
I was looking at ways to create Elevation profiles but did not find any transformers or other easy ways to do this in FME. Should I be searching for some other word?
I don't need anything fancy, the sources are some polylines and a DEM file. I would be happy with something as simple as a csv file as output.
Best answer by jdh
Here's a simplified workflow.
profile.fmw
debbiatsafe
Forum|alt.badge.img+21
Hi @aron
Perhaps try using the Chopper to convert your polyline features to a point at each vertex and use the PointOnRasterValueExtractor to get the elevation value from your DEM file. Note the output of the PointOnRasterValueExtractor is stored in a list and is not automatically exposed.
becchr
Forum|alt.badge.img+32
  • April 22, 2020
hi @aron , you could also create a surface from your DEM and drape the polylines (or points after chopping it) on that surface.
Once you got the 3D polylines, it might be worth taking a look at the ProfileGenerator on FME Hub: never tried it before but the transformers name sounds promising
aron
  • April 23, 2020
I took a look at the ProfileGenerator, but it had no documentation and I could not get it to work by just pointing the sources to it.
Forum|alt.badge.img+58
The ProfileGenerator was developed by me. It expects a 3d line as input, so if you use a SurfaceDraper to drape your lines over the DEM and then put those draped lines into the ProfileGenerator it should work. Let me know if you run into issues.
aron
  • June 9, 2020
Hi @redgeographics
I have now had some time to fiddle with this some more. Next question, what does the ProfileGenerator output? :) I would like to ad a writer after it.
aron wrote:
Hi @redgeographics
It generates a line feature with the x axis being the length along the path and the y axis being the elevation at every point.
I developed it for a specific project back then, so it may not be exactly what you need.
aron
  • June 9, 2020
Thanks! No, that was not really what I was hoping for. I would like to utput something that could be sent to a spreadsheet/table to be styled later in Illustrator.
You can use a CoordinateExtractor after the ProfileGenerator to grab those coordinates (or edit the ProfileGenerator, I'm pretty sure internally I'm doing something along those lines already)
jdh
Forum|alt.badge.img+36
  • June 9, 2020
profile.fmw
aron
  • June 11, 2020
profile.fmw
Beautiful!
stezi
  • September 17, 2020
2020-09-17_101730Hibou
olivier
Forum|alt.badge.img+7
  • April 27, 2021
profile.fmw
Hi @jdh​ !
Your solution looks interesting. I was wondering which role the Creator transformer was playing and which parameters some other transformers (VertexCreator and ChartGenerator) were using. If it is not a problem for you, could you share your workspace here? Thanks!
Best regards,
Olivier
jdh
  • April 27, 2021
olivier wrote:
Hi @jdh​ !
Best regards,
Olivier
Hi Olivier,
Unfortunately I don't have the workspace anymore. Based on the screenshot, the creator is almost certainly just a trigger with a 3D line, since I didn't have a DEM for the surfaceDraper.
The vertexCreator would be the _distance attribute (from measureExtractor) for the x and the _height (z from coordinateExtractor) as the y. I assume the chartGenerator would be a Line type with the same attributes in the data series.
stezi
  • April 27, 2021
olivier wrote:
Hi @jdh​ !
Best regards,
Olivier
it's not 100% what you were looking for. I just want to share my workbench to generate a proper profile from a 3D line. maybe it helps
olivier
  • April 28, 2021
olivier wrote:
Hi @jdh​ !
Best regards,
Olivier
Thank you very much @stezi​ ! Thanks to your flow I was able to create one for my needs leading to a profile like this one:
River_profile
