How can I publish images to arcgis server image using FME?
  • February 21, 2023
  • 5 replies
  • 145 views
arthy
Forum|alt.badge.img+8
I'm newbie on arcgis server image.
Thanks
evieatsafe
  • February 27, 2023
Hi @arthy​ thanks for your question. Writing images to ArcGIS can be a bit tricky, check out these threads (1) and (2) that go into more details. You can also check out these tutorial articles for more information on AGOL readers and writers:
If you have specific issues or questions let us know! You can attach a sample workspace and data to this thread or if you're more comfortable you can submit a support case. Happy to help :)
arthy
  • February 28, 2023
Thanks @Evie Lapalme​
I still have several questions. After reading this post, I downloaded the 2023 beta version to try the new arcgis server feature service writer based on this post
How do I write attachment to the portal along with data?
evieatsafe
  • March 1, 2023
Hi @arthy​ sorry about that! This is likely due to the ArcGIS Server Feature Service Writer not supporting attachments. In the documentation it states "Although the reader can read attachments, the writer currently cannot write them. Format attributes related to attachments are ignored." See the documentation here: https://docs.safe.com/fme/2023.0/html/FME_Desktop_Documentation/FME_ReadersWriters/arcgisfeatures/arcgisfeatures.htm
If you would like to have the ability to write attachments (images, etc.) along with a feature you can submit an additional idea. Sorry for the inconvenience.
arthy
  • March 2, 2023
@Evie Lapalme​
The these threads (1) and (2) are more relating on writing data to existing features.
The new  ArcGIS Server Feature Service Writer  is able to do that but there is a bug on the feature reader that create a big issue with the performance amd make it unusable for what I'm looking for
evieatsafe
  • March 2, 2023
@arthy​ Oh sorry to hear that! What are you experiencing, or what are you trying to do? If you could also provide your workspace and any additional files or screenshots that may help us investigate that would be appreciated. You can also submit a support case if there are any files that you would not like to share publicly. Happy to help :)
