How to visualize GeoJSON data?
  • Aug 6, 2025 10:54 AM UTC
  • 143 views
ed-progres
Forum|alt.badge.img+5
Hello,
I'm scraping data using an HTTPCaller.
One of the attributes contains GeoJSON data:
{"type":"FeatureCollection","features":[{"type":"Feature","properties":{},"geometry":{"coordinates":[[[5.96266096723135, 51.9996241913007],[5.96267141231219, 51.9996290142943],[5.96315710713663, 51.999175649922],[5.96290120337337, 51.9991708268575],[5.96266096723135, 51.9996241913007]]],"type":"Polygon"}}]}
I'd like to visualize these polygons in the Data Inspector but I don't know how to convert this data into an actual polygon.
What transformers do I need?
Thanks
Best answer by takashi
Hi ​@ed-progres ,
JSONFragmenter with these parameters might help you.
  • JSON Query: json[“features”][*]
  • Fragment as Format: GEOJSON
  • Aug 6, 2025 11:14 AM UTC
Hi ​@ed-progres ,
lambertus
Forum|alt.badge.img+25
  • Aug 6, 2025 11:22 AM UTC
​@ed-progres beside the nice method of ​@takashi you could also use the GeometryReplacer followed by a CoordinateSystemSetter.
In case you might apply this one you only need to choose the right attribute in GeometryReplacer to get the JSON fragments.
alexbiz
Forum|alt.badge.img+35
  • Aug 6, 2025 12:10 PM UTC
Here’s my two cents: if the data you’re scraping is available through a simple GET request, you can simply load it into a GeoJSON reader by using the URL as the data source.
