FME Flow 2025.1 Distributed deployment in Azure - Unable to Run a workspace
  • Aug 4, 2025 3:16 PM UTC
  • 244 views
tp_atkins
Forum|alt.badge.img+3
I have just deployed a distributed Flow (2025.1) in Azure with following configurations (this is to replace a similar deployment in Azure with 2021.1 FME Server version)
Core machine - 1
Engine machine -1
Azure storage account
Azure hosted postgresql flexible server
Azure application gateway
In addition to the internal load balancer Azure creates as part of the deployment, we also have a public load balancer associated with the core VM to allow outgoing external traffic.
A backup of the configurations from the 2021.1 FME Server is restored to the 2025.1 using the backup/restore fucntion in FME Flow. (Used an intermediate version 2024.2 to restore a backup from 2021.1 and then created a backup to restore to 2025.1, no error and everything works fine in Automation mode)
However when select a workspace and ‘Run Workspace’ option is selected, it throws a message saying: There was an error submitting the job. This is same for any workspaces (Sample, test and project specific). The error is 301 Moved Permanently.
In addition, if trying to upload a file from local machine, it throws another error called ‘There was  a problem communicating with the REST API.
No sure these are related. Anyone who has deployed FME Flow in Azure as distributed deployment and familiar with what I see above?
Thomas
Best answer by hkingsbury
a few things to check here:
  • What url do the services have? (under System Config, Networking and Email)
  • In your screenshots, what url are the network calls going to?
  • Where are your load balancers pointing? To the existing Flow, or the new one?
  • What is FME_SERVER_WEB_URL set to in fmeFlowConfig.txt?
Also have a look through here: https://support.safe.com/hc/en-us/articles/25407364556941-FME-Flow-Troubleshooting-Guide
hkingsbury
Forum|alt.badge.img+73
  • Aug 4, 2025 9:13 PM UTC
tp_atkins
  • Aug 5, 2025 12:23 PM UTC
​@hkingsbury Many thanks for pointing out the FME_SERVER_WEB_URL parameter, which was the issue. It was pointing to the http:appgateway:80 rather than https. After updating this, I also updated the ‘Change allhosts’ and that sorted everything.
Best Thomas
