How to use a floating license?
  • Aug 5, 2025 3:22 PM UTC
  • 145 views
lmengualpelay
Hello,
Sorry for the inconvenience. We've never installed a floating license. Is there a process, or do I just need to specify where it's located?
Thank you for your help.
Regards.
Best answer by alexbiz
Hi Luis,
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form-Admin-Guide/FMEInstallation/About_Floating_Licenses.htm
To run a floating license, first set up a licence server and load your licence file onto it.
Afterwards, just point the FME Form Licensing Assistant on your PC to that server.
alexbiz
Forum|alt.badge.img+35
  • Aug 5, 2025 3:37 PM UTC
Hi Luis,
lmengualpelay
  • Aug 5, 2025 4:14 PM UTC
Hi Alexbiz!
Thanks so much!!!!!!
Regards
