The only way i know of is to copy the transformer (just normal copy) and then paste it in a textfile.
The first line of the textfile shows the original transformer name.
Like this:
FACTORY_DEF * AttrSetFactory \\
FACTORY_NAME Reg_expressies
second name is what i named it, first is definitionname.
You can see the original transformer name in the Navigator, Summary Annotation, and Tool Tip.
Takashi
Thanks for the reply (:
what i found was you can
Ctrl+c Ctrl+v the desired tester to a text file to get the name and understand the transformer settings (As Gio recommended)
Secondly, the oroginal name of the transformer can be seen using
Navigator bar in the transformers section (As Takashi said)
Also, we can check the real name just byclicking
Transformer Description on the lower panel. :P
So, I guess it is correct in every case.
Thank you (:
