Generate a Point at ends of Aggregated Polyline
Hello everyone,
I am a bit puzzled with what I thought would be simple, but is giving me a difficult time.
I have aggregated polyline (Gas Main) and need to generate a point at any ends ( to buffer and capture streets within that buffer to show potential growth).
In review what I need:
A point to be created at any end of an aggregated polyline.
Exported in ArcMap Esri GDB
Thanks
  • July 17, 2019
Have you tried using a CoordinateExtractor with index -1 (end) followed by a VertexCreator to create the point?
  • July 17, 2019
Ive never used Coordinate Extractor. Will the -1 variable capture the multiple ends of the aggregated line? Dataset is gas main so I need only the points at the ends.
I can give this a try.
  • July 17, 2019
The CoordinateExtractor set at -1 will only give you the very last vertex of the aggregate geometry. If you need one point for each segment, insert a Deaggregator just before the CoordinateExtractor.
  • July 17, 2019
Let me build it out now and give it a try. I will follow up in just a few minutes. Thanks!
  • July 17, 2019
David it only created a single point but the polyline has a lot of end areas.
I need to generate a point at every endpoint so I can then buffer and capture streets within those buffers.
If I deaggregate wouldnt it make a point at the end of every segment which would be to many points.
This sure is a puzzle.
  • July 17, 2019
as I thought I used deaggregator and it made to many points. I just need the ends after its all be aggregated.
  • July 17, 2019
Here is sample of the data.
This polyline is Aggregated and I need to generate a point at each of those end points.
  • July 17, 2019
What is an "end" in this context? I thought it was the final vertex of each segment, but do you perhaps mean topological ends, i.e. en final vertex of each segment that's unconnected to any other segments?
  • July 17, 2019
I posted a photo to try and clarify. Can you see it? When I deaggregate it generates way to many points. Perhaps Im using wrong terminology when I say "end".
I have to provide a list of names that appear within a buffer from the "ends" of mains. My plan was to generate a point and buffer than spatial join for results.
Hope the photo provides more clarity.
  • July 17, 2019
Could you perhaps also upload an illustration where you've given a few examples of where the points should be in relation to the lines?
  • July 17, 2019
yes I have quick meeting then will upload that for you. Thanks
Forum|alt.badge.img+39
  • July 17, 2019
I would probably use a topology builder here and then test for nodes that only have 1 element in their list
  • July 17, 2019
For "line terminations", that would be a great solution, yes.
  • July 17, 2019
I just used Paint to mark points where "ends" of gas main is. It would be where the mains end generate a point at those ends. In other words where the main stops in real world a point there. I did not mark every end I hope this makes sense.
  • July 17, 2019
im not familiar with this. I will look into this. Do you have sample flow as listed below?
Thanks so much
jdh
Forum|alt.badge.img+28
  • July 17, 2019
Thanks so much
TopologyBuilder with the following parameters
Aggregate Handling: Deaggregate
List Accumulation/Generate List From Input Edges: _edges (or anything really)
Advanced Parameters Generate From: End Nodes Only
Then on the Node port add a ListElementCounter (_edge) followed by a Tester (_element_count = 1)
  • July 17, 2019
you are amazing. Let me try now. Will update soon as I build it up
  • July 17, 2019
Hi JDH,
I am having trouble with following:
I place in List Builder but not sure what to pick. Choices are: _edge_id, _faces, _from_node, L or R edge or face
Do I pick any of them?
Advanced parameters (End Nodes Only_. Is that in a different transformer? That option is not available in TopologyBuilder
Thanks
jdh
  • July 17, 2019
sav426 wrote:
Hi JDH,
Thanks
What version of FME are you using, there's been significant GUI changes to the transformer recently.
  • July 17, 2019
sav426 wrote:
Hi JDH,
Thanks
In 2018 this is how I create points where a line doesn't meet any other line
  • July 17, 2019
it wont write it, it ponly outputs a single point unless I explode the list but then it loses all coordinate attrbutes etc and wont let me readd. I havent been stumped like this in while :(
jovitaatsafe
Forum|alt.badge.img+11
Hi @sav426,
the -1 index is the last coordinate in the feature. There's a bit more information on the CoordinateExtractor here that explains the parameters in the transformer.
