Filter/Sample data from multiple gdb inside feature reader
  • Aug 31, 2023 7:24 PM UTC
  • 11 replies
  • 174 views
marta.podsiad
Forum|alt.badge.img+12
I have multiple gdb with feature classes. I would like to get one feature class per each gdb as a sample. The catch is that I do not want to read all data as it's massive. I would like to filter/sample it while reading something similar to SQL Creator
Best answer by nielsgerrits
Yes this is a known thing. One way to work around this is to use 2 FeatureReaders. Use the first one to read the schema only, use these as input for the second FeatureReader.
Attached sample workspace.
FeatureReaderSample(2021)
nielsgerrits
Forum|alt.badge.img+67
In the FeatureReader you can set the Max Features to Read parameter to 1. I think this will result in one feature per featureclass.
If this results in only one feature for all featureclasses you can chain two FeatureReaders together, the first one reading the schema's, feeding it to the second one in Feature Types to Read.
marta.podsiad
  • Sep 1, 2023 10:48 AM UTC
Hi, I have try to play with the Max Features number. Unfortunately, it reads the specified number of records from one feature only
nielsgerrits
nielsgerrits
  • Sep 1, 2023 11:12 AM UTC
marta.podsiad
  • Sep 1, 2023 11:13 AM UTC
This is not going to work for me as I have 10 gdb with over 300 feature classes. Adding 300 feature classes in not really the solution
nielsgerrits
Please check the sample workspace.
  • FeatureReader to find all *.gdb in directory.
  • FeatureReader to read schema's of all *.gdb in the directory.
  • FeatureReader to read every schema of all *.gdb in the directory, limited by number of features.
marta.podsiad
It works. Thank you very much for your help
nielsgerrits
Cheers :)
marta.podsiad
I am just wondering if there is a way to get the size of each feature class in gdb
nielsgerrits
Using a PythonCaller, arcpy and getcount you can, but nothing I know of FME only.
nielsgerrits
This was harder than I expected, but I suck in Python so no surprises...
Make sure you have ArcGIS Pro installed and licensed. In the navigator under Scripting set Python Compatibility to Esri ArcGIS Python 3.6+.
Attached working sample.
