I have a dynamic replication workspace which reads the contents of one file gdb and uses its schema to truncate/overwrite another. I've added some contour datasets to both gdbs that are static, and don't want them being included in the replication because of the time overhead they add in reading and writing. Mid-workspace workaround is the humble Tester, but not reading at all would be better. I've had a google of regular expressions to use for this, rubular rejected the solutions here ( https://stackoverflow.com/questions/2078915/a-regular-expression-to-exclude-a-word-string ), and couldn't think of how the merge filter would be used for it.
I need to exclude feature classes like '%Contour%' and also those like '%0_5m' - in the latter case it can be an 'ends with' scenario as it is always at the end of the feature class name.
