Fanout expression using wildcards?: Need to split a shapefile into six shapefiles based on the third character in this string: US5ME54M. That 3rd character can be one of six characters, 1 thru 6.
  • Jun 28, 2023 2:27 PM UTC
  • 9 replies
  • 113 views
jhawks
Forum|alt.badge.img+7
jhawks
  • Jun 28, 2023 2:42 PM UTC
Thus if cell name = US6whatever write it to the 6 shapefile, US5whatever write it to the 5, etc.
Forum|alt.badge.img+54
  • Jun 28, 2023 2:57 PM UTC
You can just create a fanout attribute using the @Substring expression
jhawks
  • Jun 28, 2023 3:37 PM UTC
Thanks! Though I don't quite have the Attribute Value correct. So Value gets the CELL ?
  • Jun 28, 2023 3:41 PM UTC
If the attribute containing the string is called CELL then you want
@Substring(@Value(CELL),2,1)
 @Value(CELL) is the string to use
2 is the start index (index starts at 0 so this is the third character)
1 is the number of characters to keep from that point
jhawks
  • Jun 28, 2023 3:57 PM UTC
Still no go. AttributeCreator (AttrSetFactory): An error occurred while evaluating the above expression. If the failed expression is arithmetic, check to ensure there is a numeric value specified as the substitution value for null, empty and missing attributes.
AttributeCreator (AttrSetFactory): AttributeCreator: Failed to evaluate input expression: @Substring(@Value(CELL),6,5,4,3,2,1)
Does it need to know it's splitting on the 3rd character?
  • Jun 28, 2023 3:58 PM UTC
I've added some explanation to my above post, you should enter it exactly as i posted
jhawks
  • Jun 28, 2023 4:03 PM UTC
Writing, but still not splitting, creates 6 duplicate shapes.image
  • Jun 28, 2023 4:06 PM UTC
Once you've got an attribute to Fanout on, you use this as the Shapefile Name within the writer. You only need one writer.
jhawks
  • Jun 28, 2023 4:17 PM UTC
That's it! thank you very much!!
