Extract unique values from attribute table using PythonCaller
  • Apr 8, 2021 12:13 PM UTC
  • 11 replies
  • 216 views
dustin
Forum|alt.badge.img+36
Hello - I have a file geodatabase where most feature classes contains an attribute 'text_desc'. I would like to extract all unique values, and concatenate those into a single comma-separated attribute to generate a report. Due to slow gdb read times in FME, I would like to do this in PythonCaller for efficiency.
Is this possible?
Best answer by ebygomm
I can, but with my limited experience, so far I have been unsuccessful in getting it work.
import fme
import fmeobjects
import arcpy
def getUnique(feature):
    arcpy.env.workspace = FME_MacroValues['SourceDataset_GEODATABASE_FILE']
    fc = feature.getAttribute('featureclass{}')
    fn = feature.getAttribute('fieldname')
    valueList = []
    for f in fc:
        with arcpy.da.SearchCursor(f,fn) as SCur:
            for row in SCur:
                if not row[0] in valueList:
                    valueList.append(row[0])
    feature.setAttribute("unique_values",",".join(valueList))
You could do this if you have the featureclasses stored in a list. There's probably more efficient ways
  • Apr 8, 2021 12:21 PM UTC
If this is an Enterprise Geodatabase (SDE), why not let the database do the work for you? It's going to so much faster than anything you could do with FME. Example SQL that you can use in e.g. a SQLExecutor:
SELEC DISTINCT text_desc
FROM my_feature_class
You will then only get the unique values back, and you can then use e.g. an Aggregator to concatenate the values.
dustin
  • Apr 8, 2021 12:23 PM UTC
Sorry, this is a File Geodatabase.
Forum|alt.badge.img+54
  • Apr 8, 2021 1:35 PM UTC
Can you use arcpy?
dustin
  • Apr 8, 2021 1:36 PM UTC
Can you use arcpy?
  • Apr 8, 2021 1:52 PM UTC
A couple of examples, need a parameter holding the gdb location and the feature triggering the pythoncaller needs to have attributes holding the featureclass name and the fieldname
import fme
import fmeobjects
import arcpy
    #get parameter with location of fileGDB
    #get featureclassname
    fc = feature.getAttribute('featureclass')
    #get field name
    row=[x[0] for x in arcpy.da.TableToNumPyArray(fc,fn)]
    uniquelist = set(row)
    #create new attribute with concatenated list joined with comma
    feature.setAttribute("unique_values",",".join(uniquelist))
or
import fme
import fmeobjects
import arcpy
    with arcpy.da.SearchCursor(fc,fn) as SCur:
        valueList = []
        for row in SCur:
dustin
  • Apr 8, 2021 2:16 PM UTC
Thanks @ebygomm, the second works well with one feature class being input. If I wanted to query multiple feature class, such as 'Rivers' and 'Lakes', how could I go about that?
  • Apr 8, 2021 3:42 PM UTC
Is it the same fieldname for each feature class? Do you want a single attribute containing all values in both featureclasses or something else?
dustin
  • Apr 8, 2021 3:49 PM UTC
Yes, it is the same fieldname "text_desc" on each feature class. I would need a single attribute output containing unique values of "text_desc" from all the feature classes. So, if a feature from Rivers had text_desc=1, and another Rivers had text_desc=2, and a Lakes feature had text_desc=1, the result would be "unique_values=1,2"
  • Apr 8, 2021 4:03 PM UTC
import fme
import fmeobjects
import arcpy
    valueList = []
    for f in fc:
            for row in SCur:
dustin
  • Apr 8, 2021 4:36 PM UTC
Thanks @ebygomm​ ! It worked great.
  • Apr 8, 2021 5:51 PM UTC
This is a great solution, but it can be somewhat slow if there are a lot of unique values. Here's a slightly different take that has a more linear performance, since it uses the Python built-in set function rather than doing repeated list lookups:
import fme
import fmeobjects
import arcpy
   valueList = []
   for f in fc:
       with arcpy.da.SearchCursor(f, fn) as cursor:
           valueList.extend(list({row[0] for row in cursor}))
   feature.setAttribute("unique_values",",".join(set(valueList)))
Tested with ~1.5 million records containing ~130k unique values (medium length strings):
  • Using list lookup: 15 minutes
  • Using sets: 17 seconds
If the number of unique values is very small, the two solutions are practically as fast.
