Dynamic ESRI.shp reader
  • Nov 28, 2019 4:12 PM UTC
  • 63 views
pcarrerabalsell
Forum|alt.badge.img+5
I am trying to build a workbench that transforms SHP data to DGN files. I have a huge amount of shp files, each one with the same attributes. Despite this, in some cases the width of char type Attribute "ID" is not the same. Mostly width is 20, but in some cases I cannot predict this value.
Right now I have an issue when the ID width is not 20, because shp reader is defined this way and I get an error.
I would use a single workbench for all SHPS. How to make reader accept multiple ID width values?
Best regards,
Pol
@pcarrerabalsell When you add the Shape file reader, you can use the Merge Feature Type. This should largely ignore the schema of the source shape file.
If this doesn't work, would you be able to attached a couple of the shape files and your
