Does FTPCaller consider sftp/ftps URL the same way ?
  • November 28, 2022
  • 57 views
Hello everyone,
I searched a lot about this topic but nothing matched the same problem.
I have a functionnal ftps URL that return the good file in filezila. But when using it with the FTPCaller, it return a timeout. Whatever the parameters are.
But if I declare the URL as a SFTP, it does the job.
It work here because the server do accept the query with sftp but if not, I am afraid I'll be block with the ftps only.
Does someone face the same problem ? Did you find why and how counter it ?
Thanks in advance ! Have a good day.
danminneyatsaf
Forum|alt.badge.img+12
Hi @prive​ sorry to hear you're having issues with the FTPCaller. I have a few follow up questions that will help myself and other users better understand your issue:
