Distinct values to export?
  • February 4, 2014
  • 17 views
Hello all,
I'd like to export all unique values of multiple attributes without having to use an aggregator > attributerenamer > attributecreator.
What I've got:
Table
ID,COLOR,TYPE
1,Blue,Slide
2,Red,Slide
3,Green,Merry-go-round
4,Green,Slide
What I want my export to look like:
COLUMN,VALUE,COUNT
TYPE,Slide,3
TYPE,Merry-go-round,1
COLOR,Blue,1
COLOR,Red,1
COLOR,Green,2
Now I know I can achieve this with alot of DuplicateRemovers or Aggregators, but I've got 100+ columns like this... Is there any other way?
Thanks in advance.
  • February 4, 2014
have you looked at the DuplicateRemover? You can select multiple attributes to get all the unique combinations of those attributes.
David
  • February 4, 2014
Hey David,
Yes, I've already used that, I actually want the unique values per attribute. So I end up using 100+ DuplicateRemovers or Aggregators (so I can COUNT as well). But I was wondering if there's a better way.
  • February 4, 2014
Thanks alot David, got exactly what I needed!
