Define parameters in database which use as JSON query in JSONExtractor
  • Jun 4, 2024 5:07 AM UTC
  • 155 views
leroy
Hi folks,
In my situation, I am using JSONExtractor but the JSON queries differ between the testing and production environments. Rather than creating and maintaining two separate FME scripts, I prefer to define the target attributes and JSON queries in a database. This way, the correct configuration is used based on the environment's database.
However, the challenge is that multiple rows of configuration records are retrieved (with target attributes and JSON queries as table columns). Is there an example that shows how to convert these database records and assign them to the JSONExtractor in a generic way?
Thank you very much!
ali-safe
Forum|alt.badge.img+24
  • Jun 7, 2024 3:42 PM UTC
Hi @leroy,
Thanks for posting your question. To best assist you, could you share the database format you're using and possibly provide a general workflow breakdown with screenshots? Your input will be super helpful. Thanks a lot!
