Convert Date/Time stored as Double to an ISO Date
dilip
Forum|alt.badge.img+5
Hi all,
For some reason an application is storing a date/time field as 'Double' - ''201805241214'' in this format, but the Date converter function does not recognise this as its a double field type, any help is greatly appreciated,
Forum|alt.badge.img+43
  • August 7, 2018
Are you providing the source date format? e.g. %Y%m%d%H%M
  • August 7, 2018
Agree with @egomm, you'll have to specify the source format.
The issue is the timestamp is "missing" the seconds part, which is why I suspect FME don't automatically recognize it as a timestamp.
