Autodesk A360 Drive
erik_jan
Forum|alt.badge.img+18
I have a number of DWG files, stored on the Autodesk A360 drive.
I was hoping the A360Connector could be used to download these files.
But the connection is pointing to the A360 projects folder only.
Does anybody know how I can download (and upload) from the A360 Drive using FME
Any help is appreciated.
Best answer by mark2atsafe
So, looks like this is another A360 product separate to what we support. Apologies for that. Probably the best thing is to file this as an idea to gather votes, and I'll push for it to happen at Safe. Seems odd that we would support one without the other, but that does seem to be the case.
mark2atsafe
Forum|alt.badge.img+45
I don't really see any documentation or information on what exists outside of a projects folder or how to get at it. I'll ask an expert at Safe, but if you could post a screenshot at all, that would be a big help.
erik_jan
  • June 22, 2017
After connecting to A360 in the browser I see these 3 options:
The A360Connector seems to connect only to the first (A360).
But my files are stored on the second (A360 Drive).
mark2atsafe
Ah, I see. Thanks. I've asked our A360 developer and will let you know what he says. Like I said, I don't see anything in the documentation that mentions A360 Drive, so my guess is that it's not supported - but we'll see.
mark2atsafe
  • June 23, 2017
erik_jan
  • June 23, 2017
@Mark2AtSafe I have posted the idea here. Might be good to try and add it to the Hub.
mark2atsafe
Is there a web service/api? If I could just create a web service connection like the others on the hub, then I would try, but I don't know if that's possible.
