Open
PDF Reader: Support Bookmarks
Related products:Integrations
lorenrouth
The current PDF Reader can access a lot of data, but not bookmarks. This would be extremely helpful when dealing with large documents.
Here is a use case:
I have a 2,500 page PDF construction submittal with bookmarks throughout. It is common for contractors to submit these files after a building project is complete. They often have crucial maintenance info for O&M. Bookmarks, or some other index, could be linked to a BIM model where it would be possible to locate the equipment visually and then access related info through a link in the model. The goal is to reduce response time when things break down.
Just the ability to merge bookmark data with other file formats would be very helpful.
Thanks,
Loren
Be the first to reply!
