2dgridaccumulator
I need to generate a grid with dimension keepped from attribute value... but fme log error say that grid_cell_count must be positive integers ...
is there a way to forcing an attribute's type to integer ?
thx a lot
gd day
Best answer by takashi
It might be a kind of bug of the 2DGridAccumulator.
In the interim, try setting "Yes" to the "Input is Ordered by Group" parameter.
Group By: coupe_h  coupe_v  fid
Input is Ordered by Group: Yes
FME 2015.1.1.0 build 15515
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • July 27, 2015
Hi
Try inserting an AttributeRounder with zero decimal places.
David
  • July 27, 2015
I TRY IT WITH NO RESULT :/
  • July 27, 2015
I found it (attribute value was not the good one )... now i have another problem, transformer 2gridaccumulator can't read number of horizontal and vertical tiles... when i set it manually, there is no problem, but if i prcise that it should be refered to attribute value, he create only one point :/
pratap
Forum|alt.badge.img+11
  • July 27, 2015
Select those two attributes in group by and use
  • July 27, 2015
Hi Pratap,
Thx for ur answer,
i tried it and same result (he create only one point) ..
pratap
  • July 27, 2015
Does that mean it is creating 1 point, instead of 5 rows & 3 columns?
  • July 27, 2015
yes, numbers of rows and columns are stored in another attribute (coupe_v and coupe_h),
The transformer can't read those values and create only one point ..:/
pratap
  • July 27, 2015
"The transformer can't read those values"...
Have you checked by adding these attributes "coupe_v and coupe_h" in Group By option? I have seen in the screenshot only "fid" is selected.
  • July 27, 2015
Yes i tried it believe me ... :(
pratap
  • July 27, 2015
Sorry I didn't mean in this way...
It is strange, why it is working when values are constants and not when values are variables... I dont have latest version to check...
Anyhow please check the values whether "coupe_v and coupe_h" attributes are passing after this 2gridaccumulator transformer or not.
  • July 27, 2015
nielsgerrits
Forum|alt.badge.img+54
I had a problem like this with the tiler. (GeometryExtractor-BoundingboxReplacer[attributes for long and short side]-Tiler[tile width = @Value(long)/2 etc.]). After a while I realized the error "GRID_CELL_SIZE must be positive numbers" was caused by disabeling the connection to the Tiler instead of disabeling the transformer. This might be your problem as well...
  • July 29, 2015
Thanks a lot for ur answer ! Thank You very much Takashi it work when i set yes to input in order by group :)
Thank You Pratap for your help, also  NielsGerrits thank u too :)
Good day
