Map frame , title etc in 3D PDF
Hi I am having trouble adding map marginalia to a 3D PDF I am creating. I create a surface and write that to 3D PDF. Nothing I add using the example at https://community.safe.com/s/article/creating-pdf-cartographic-output works. When I output it to 2D it is working. So the question is, is it possible to add a "frame" around the #D view and Title boxes etc?
  • May 2, 2017
read 3D view
Forum|alt.badge.img+50
Are you adding it as a 3D feature? If not try extruding the frame a little bit so it is a proper 3D object.
