I am converting an excel spreadsheet to an esri geodatabase feature class of points. Working well so far, except for one field of elevation values. There was no standard of input and the values are varied. For example:
- 75 feet
- 75 ft.
- 75 ft
- 75f
- 75 MSL
- 25 m / 75 f
If it weren't for the last example, which occurs too often to waste time updating manually, I'd just use a string replacer to extract just the numbers, but in that last example, I'd end up with 2575 instead of just 75. I'm guess that first I need to remove everything before and including the '/', and then can use a stringreplacer with regular expression '[0-9]+' . Also, I've gotten another spreadsheet of data in which "##m" occurs. Those rows would need to be converted to feet. Hoping this is solvable with transformers, as the data is not to be edited.
