merge multiple lines into one
i tried to merge multiple lines into only one line, but the difficult is, that also connected lines on a course between start- and end-Point should be merged into the "one line"
with linejoiner the lines were only merged until the next Connection.
has anyone an idea?
  • October 20, 2016
Hi @sebastiangoerck, you can transform them into a single MultiCurve (IFMEMultiCurve) geometry using the Aggregator transformer.
:-) sometimes it is so simple, thank you!
no i have Aggregate it, but the next step is to deaggregate it, by endnodes.
any idea?
itay
Forum|alt.badge.img+17
  • October 20, 2016
Have you tried to use the group by setting in the aggregator? that will aggregate your features per group.
i have connected the endnode Reader to the aggregator, then i have tried to Group by endnode Name, but the result is not that what i expect.
the Count of objects were 5 but in the inspector were one highlighted
itay
  • October 20, 2016
Strange since in the display control there are 5 aggregates, what are the values in the Name attribute? are they all the same ?
the attributes were separated by the endnode names
has nobody an idea?
jpvo
Participant
  • Participant
  • March 1, 2017
Deaggregating by Endnode..You should be able to do it with a TopologyBuilder.
One more thing, if you want to deaggregate by spatial connection, you can do it as follow:
spatialaggregate.fmw
I hope it helps.
.JP
Hi, topologybuilder was the right transformer...thanks
esaka
Participant
  • Participant
  • October 8, 2018
I think,
the first step should be "NetworkTopologyCalculator". It is connecting to the lines and it is creating "_network_id".
the second step should be "Aggregator" (group by: "_network_id")
  • December 21, 2022
I am in the same situation as the one initially described by you and I saw that you found a solution, but I did not manage to solve it using everything that was written here.
Can you describe to us all the steps taken to create a single line
Thank you
hi,
as "esaka" wrote is the "NetworkTopologyCalculator" the right Transformer. It create the "_network_id". then you can use this to aggregate or something else.
otherwise you have to explain your issue more detailed.
  • January 9, 2023
Yes, it is a very good solution and it works great. The problem I encounter is that after the aggregator, IFMEMultiCurve type lines result.
What I would like is to result in a polyline that I can store in the poistgis database.
Or maybe I could also store this result in the database, but I don't know how.
Thanks a lotpoliline
danminneyatsaf
Forum|alt.badge.img+12
Hi @alain2002​ you could try using the GeometryCoercer transformer to change the geometry type to fme_line.
